주요 콘텐츠로 건너뛰기
PowerBook G3 Wallstreet Keyboard Replacement
필요한 것
  1. PowerBook G3 Wallstreet Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
  2. PowerBook G3 Wallstreet Keyboard Replacement: 2 단계, 이미지 1/1
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
  3. PowerBook G3 Wallstreet Keyboard Replacement: 4 단계, 이미지 1/1
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
  4. PowerBook G3 Wallstreet Keyboard Replacement: 5 단계, 이미지 1/1
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
  5. PowerBook G3 Wallstreet Keyboard Replacement: 6 단계, 이미지 1/1
    • Your laptop should look approximately like this.
결론
다른 8명이 해당 안내서를 완성하였습니다.
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 2개
The first iFixit guide?
Landon Messer - 답글
Yes sir! (text minimum)
guardian10 -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 23
30일 전: 59
전체 시간: 20,466
