주요 콘텐츠로 건너뛰기
PowerBook G4 Aluminum 12" 1-1.5 GHz RAM Replacement
필요한 것
  1. PowerBook G4 Aluminum 12" 1-1.5 GHz RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Use a coin to turn the battery locking screw 90 degrees to the right.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 12" 1-1.5 GHz RAM Replacement, RAM: 2 단계, 이미지 1/1
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. PowerBook G4 Aluminum 12" 1-1.5 GHz RAM Replacement: 3 단계, 이미지 1/1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connectors.
결론
다른 40명이 해당 안내서를 완성하였습니다.
첨부 문서
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 한 개
Why does my computer only show 768mb RAM after the upgrade? 1 RAM slot is the soldered 256mb and the other is 1gb.... Hm...
iamkiyoshi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 20,027
