이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Replacing the factory-installed Bluetooth 1.1 board.
필요한 것
Use a coin to turn the battery locking screw 90 degrees to the right.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
On the keyboard, remove the F1, F2, F11, and F12 keys.
This is scary - take a deep breath before continuing. Place your index finger under the upper left corner of the key and lift up until you hear a click. Then, transfer your finger to the left edge of the key and lift up to pull the key off.
You're freeing the two tabs on the left of the key from the two small holes in the plastic scissors mechanism.
Turn the computer over and open it up.
Remove the following 14 screws:
Six 2.5 mm Phillips on either side of the keyboard area.
Five 4.5 mm Phillips on the left half of the keyboard area.
One 7 mm hex in the upper left corner of the upper case (a T6 Torx driver will do the job nicely).
One 15 mm Phillips in the upper middle of the keyboard area.
One 16.5 mm hex in the upper right of the upper case (again, a T6 Torx driver will work well).
Peel up the two pieces of foil tape on the left side of the keyboard area.
Carefully disconnect the microphone and power cables from the logic board. Using your fingernails or a dental pick, carefully pry the connectors from their sockets. Make sure you're pulling only on the connector and not on the socket.
Remove the single Phillips screw from the reed switch board on the right side of the computer.
Deroute the cable connecting the reed switch board to the DC-to-DC board.
Peeling up yellow tape as necessary, remove the following 8 screws:
One 4.5 mm Phillips on the right side of the heat sink.
Three 6 mm Phillips near the display.
Two large 7.5 mm Phillips with springs (don't forget to remove the springs). If the springs are not releasing, needle nose pliers can help get this done.
Two 13 mm screws from the left side of the heat sink and the right side of the fan.
Remove the following five screws:
One 3 mm Phillips near the screen latch (mind the big magnet on the screen latch).
Two 3.5 mm Phillips attaching the EMI fingers to the metal framework.
One 10 mm Phillips near the optical drive.
One 14 mm long 4 mm standoff in the upper left corner. You can remove this standoff either with a 4 mm nut driver or needlenose pliers.
Lift the EMI fingers above the battery connector away from the metal framework.
Disconnect the multicolor connector from the upper right corner of the logic board.
Remove the following 2 screws:
One Phillips buried under the cable to the right of the fan area.
One Phillips holding down the display data cable on the left side of the computer.
Remove the two Phillips screws from the upper right corner of the computer.
Remove the newly-liberated small metal bracket.
다른 2명이 해당 안내서를 완성하였습니다.
