소개
This unit provides power to the machine, allows the battery to charge, and provides sound capability.
  1. Use a coin to turn the battery locking screw 90 degrees clockwise.
    • Use a coin to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. Remove the four Phillips screws from the memory door.
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. Remove the following 8 screws:
    • Remove the following 8 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Two 12 mm Phillips on either side of the memory compartment.
    • Four 16 mm Phillips along the hinge.
  4. Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
    • Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
    • Remove the three 3 mm Phillips screws.
    • When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  5. Turn the computer 90 degrees clockwise so that the hinge faces you.
    • Turn the computer 90 degrees clockwise so that the hinge faces you.
    • Remove the bottom 5 mm Phillips screw on either side of the hinge (two total).
  6. Rotate the computer 90 degrees clockwise, so that the ports face you.
    • Rotate the computer 90 degrees clockwise, so that the ports face you.
  7. Turn the computer over and open the display.
    • Turn the computer over and open the display.
    • Remove the two 1.5 mm hex screws in either corner, next to the display (a T6 Torx driver will work, but repeated use will strip the screws).
  8. Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Grasp the back corners of the upper case and pull up. Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  9. Rotate the upper case up and toward the screen, so that the upper case rests against it.
    • Rotate the upper case up and toward the screen, so that the upper case rests against it.
  10. Remove the orange tape securing the trackpad ribbon to the logic board.
    • Remove the orange tape securing the trackpad ribbon to the logic board.
    • Disconnect the trackpad ribbon from the logic board.
    • Remove the upper case from the computer.
  11. Remove the 9.5 mm silver Phillips screw from the top of the right ambient light sensor board.
    • Remove the 9.5 mm silver Phillips screw from the top of the right ambient light sensor board.
    • Remove the small 3 mm black Phillips screw from the bottom of the board.
  12. Lift the right ambient light sensor board from the computer.
    • Lift the right ambient light sensor board from the computer.
  13. Remove the two black Phillips screws from the right speaker.
    • Remove the two black Phillips screws from the right speaker.
    • Lift the speaker away from the logic board and place it aside
  14. Use your fingernail to flip up the black plastic flap locking the modem cable in place.
    • Use your fingernail to flip up the black plastic flap locking the modem cable in place.
    • Slide the modem cable from its connector.
  15. Disconnect the 13 indicated cables, removing tape as necessary.
    • Disconnect the 13 indicated cables, removing tape as necessary.
    • When re-installing the board, make sure the two small connectors at the right hand side are above the board before inserting the screws.
  16. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  17. Remove the following 8 Phillips screws from the logic board:
    • Remove the following 8 Phillips screws from the logic board:
    • Three 6.5 mm in the upper left corner.
    • Five 4.5 mm around the edges.
  18. Two cables still connect to the logic board and must be removed before pulling the board entirely out of the computer.
    • Two cables still connect to the logic board and must be removed before pulling the board entirely out of the computer.
    • Use a spudger to gently (very gently) pry up the left side of the logic board.
    • If the logic board does not immediately come free, it may be necessary to soften the thermal paste between the logic board and heat sink. You can soften the thermal compound using a hairdryer. Move the hairdryer back and forth between the two fans about one inch above the logic board for one minute. At this point, the logic board should now come free easily.
  19. Disconnect the DC-In connector from the left side of the logic board.
    • Disconnect the DC-In connector from the left side of the logic board.
  20. Disconnect the battery cable from the front, left corner of the logic board.
    • Disconnect the battery cable from the front, left corner of the logic board.
  21. Grasp the logic board at the left edge with one hand and at the thinnest section with the other hand. Lift the left edge of the board up to approximately a 30 degree angle (if you don't have your protractor handy, just lift until the DVI port clears the right hinge).
    • Grasp the logic board at the left edge with one hand and at the thinnest section with the other hand. Lift the left edge of the board up to approximately a 30 degree angle (if you don't have your protractor handy, just lift until the DVI port clears the right hinge).
    • Once the logic board clears the ports, slide it out to the left.
  22. Important: when you reinstall a logic board, you'll need to replace the thermal paste that goes between the processor on the logic board and the heat sink. Failure to remove the old paste and apply a new layer can cause the computer to overheat and sustain damage.
    • Important: when you reinstall a logic board, you'll need to replace the thermal paste that goes between the processor on the logic board and the heat sink. Failure to remove the old paste and apply a new layer can cause the computer to overheat and sustain damage.
    • To properly reassemble your PowerBook, you'll have to clean off and replace the old thermal compound. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
  23. Use a firm plastic edge to scrape the thermal material off the processor.
    • Use a firm plastic edge to scrape the thermal material off the processor.
    • When replacing the logic board, make sure all cables are routed around and above - not under - it, and to connect the two cables that do go beneath before pushing the board into place.
    • Place the logic board back in the computer, trying not to move it around once the processor has come into contact with the newly-applied thermal paste.
  24. Remove the two 3 mm black Phillips screws from the left ambient light sensor board.
    • Remove the two 3 mm black Phillips screws from the left ambient light sensor board.
    • Lift the left ambient light sensor board out of the computer, removing tape as necessary.
  25. Deroute the Bluetooth and RJ-11 cables from around the left side of the speaker.
    • Deroute the Bluetooth and RJ-11 cables from around the left side of the speaker.
  26. Disconnect the speaker cable from the DC/Sound card.
    • Disconnect the speaker cable from the DC/Sound card.
  27. Remove the 4 mm hex nut from below the left speaker.
    • Remove the 4 mm hex nut from below the left speaker.
    • Remove the 3 mm black Phillips screw from bottom left corner of the speaker assembly, to the left of the battery compartment.
  28. Lift the speaker assembly (including the right speaker) out of the computer.
    • Lift the speaker assembly (including the right speaker) out of the computer.
  29. Remove the two 4.2 mm silver Phillips screws from the left corners of the PC card cage.
    • Remove the two 4.2 mm silver Phillips screws from the left corners of the PC card cage.
    • Next the two 6.8 mm shouldered screws go on the right side of the card cage.
  30. Lift the PC card cage up and remove it from the computer.
    • Lift the PC card cage up and remove it from the computer.
    • When replacing the PC card cage, make sure you attach it to the post on the metal eject button.
  31. Remove the two 4.2 mm silver Phillips screws from either side of the large orange Airport ribbon.
    • Remove the two 4.2 mm silver Phillips screws from either side of the large orange Airport ribbon.
  32. Lift the Airport card out of the computer and slide a spudger between the card and the antenna connector to disconnect the cable from the card.
    • Lift the Airport card out of the computer and slide a spudger between the card and the antenna connector to disconnect the cable from the card.
    • Deroute the antenna cable from the side of the card, removing tape as necessary.
    • You don't need to remove the Airport card entirely. We're just trying to free up the Airport antenna cable.
  33. Using a spudger, pry up the Bluetooth board from the cavity in front of the battery compartment.
    • Using a spudger, pry up the Bluetooth board from the cavity in front of the battery compartment.
  34. Disconnect the Bluetooth antenna cable from the Bluetooth board.
    • Disconnect the Bluetooth antenna cable from the Bluetooth board.
  35. Close the display and turn the hinge side of the computer to face you.
    • Close the display and turn the hinge side of the computer to face you.
    • Remove the remaining Phillips screw on either side of the hinge (two screws total).
  36. Open the display and turn the computer so the screen faces you.
    • Open the display and turn the computer so the screen faces you.
    • Remove the 10 mm T8 Torx screw closer to the display on either side of the hinge (two screws total).
    • When replacing the display, make sure that the right screw pins down the ground loop from the display data cable.
  37. Be sure to support the display with one hand while removing the final two screws.
    • Be sure to support the display with one hand while removing the final two screws.
    • Remove the longer 13 mm shouldered T8 Torx screw remaining on either hinge (two screws total).
  38. Lift the display off.
    • Lift the display off.
  39. Remove the following 7 Phillips screws from the heat sink:
    • Remove the following 7 Phillips screws from the heat sink:
    • Four 4 mm silver screws.
    • Two 5 mm black screws.
    • One 9 mm silver screw in the upper left corner of the left fan.
  40. Remove the heat sink from the case, minding the left corner, as it tends to catch in the case (the fans will come out with the heat sink).
    • Remove the heat sink from the case, minding the left corner, as it tends to catch in the case (the fans will come out with the heat sink).
  41. Disconnect the 4-pin power cable and orange ribbon cable from the DC/Sound card.
    • Disconnect the 4-pin power cable and orange ribbon cable from the DC/Sound card.
  42. Remove the T8 Torx screw from the RJ-11 board.
    • Remove the T8 Torx screw from the RJ-11 board.
    • Remove the 5 mm standoff that secures the DC/Sound card to the lower case using a nut driver or pliers.
  43. Do not pull the DC/Sound card out entirely. You will be disconnecting the Bluetooth cable in the next step.
    • Do not pull the DC/Sound card out entirely. You will be disconnecting the Bluetooth cable in the next step.
    • Lift the DC/Sound card out of the computer and turn it over.
    • Disconnect the Bluetooth cable from the DC/Sound card, removing tape as necessary.
  44. Use your thumbs to slide the RJ-11 board away from the sound card in the same direction you would disconnect a cable. This is your chance to get out some aggression, as the board will most likely be very tight and requires a good deal of force to remove. Don't get carried away though - don't hold onto the power connector and don't put too much actual force on the card itself.
    • Use your thumbs to slide the RJ-11 board away from the sound card in the same direction you would disconnect a cable. This is your chance to get out some aggression, as the board will most likely be very tight and requires a good deal of force to remove. Don't get carried away though - don't hold onto the power connector and don't put too much actual force on the card itself.
    • The DC/Sound card should now be free.
결론
다른 16명이 해당 안내서를 완성하였습니다.
첨부 문서
iRobot
회원 가입일: 2009년 09월 24일
1 평판
안내서 623개 작성하였습니다
The Tools Used list specifies a #6 Torx wrench, but in step 7 it says a 1.5mm hex wrench is preferred. This is good to know ahead of time since a #6 Torx wrench is not available from the local hardware store, but a 1.5mm hex wrench is.
Thermal paste is required for reassembly at step 17.
ewoudenberg - 답글
I follow the instruction to open the box, but you don't have to take the whole computer apart to get to the part. You can work on the side where the part is and it is much more easier. The chance of breaking a wire is less likely. I recommend that once the box is open and the mainboard is exposed, that the person on unscrew the left speakers, remove the screw near the small left speaker. Remove the screws that secure the PC Card tray, remove the tray. Remove the screws that secure the electronic eye to the top left, remove the screw that secure the dc board and the parts is ready to come out.
charleslundy - 답글
Agreed - I just removed the DC/sound board without touching the logic board! very happy =)
JP
Jesal -
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 24,188
