소개
This guide will show you how to remove the Airport Extreme/Bluetooth card from your PowerBook.
필요한 것
Use a coin to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the following 10 screws:
Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
Four 3 mm Phillips around the memory compartment.
Four 16 mm Phillips along the hinge.
Rotate the computer 90 degrees clockwise so the ports face you.
Remove the three 3 mm Phillips screws along the edge of the lower case.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
Remove the two 3 mm Phillips screws securing the left ambient light sensor. One is silver and one is black, or both black.
Disconnect the cable from the Logic board and remove the left ambient light sensor from your computer.
Remove the two Phillips screws holding the Airport Extreme/Bluetooth card to the lower case.
다른 10명이 해당 안내서를 완성하였습니다.
