소개
Keys sticky from spilling that 64 oz. soda all over your PowerBook? This guide will show you how to replace your keyboard and will have you up and typing in no time.
필요한 것
Use a coin to turn the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Remove the following 10 screws:
Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
Four 3 mm Phillips around the memory compartment.
Four 16 mm Phillips along the hinge.
Rotate the computer 90 degrees clockwise so the ports face you.
Remove the three 3 mm Phillips screws along the edge of the lower case.
When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
Peel back the black plastic shielding on either side of the keyboard (there are two pieces).
다른 11명이 해당 안내서를 완성하였습니다.
