주요 콘텐츠로 건너뛰기
PowerBook G4 Aluminum 15" 1.67 GHz RAM Replacement
필요한 것
  1. PowerBook G4 Aluminum 15" 1.67 GHz RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Use a coin to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 15" 1.67 GHz RAM Replacement, RAM: 2 단계, 이미지 1/1
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. PowerBook G4 Aluminum 15" 1.67 GHz RAM Replacement: 3 단계, 이미지 1/1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connectors. If there is a second RAM chip installed, pop it out in the same manner.
결론
다른 28명이 해당 안내서를 완성하였습니다.
첨부 문서
Andrew Bookholt
586,444 평판
안내서 619개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 20
전체 시간: 13,114
