소개
Backlight not working? Use this guide to replace a broken display inverter.
필요한 것
Remove the two 6.3 mm Phillips screws near the lower left and right corners of the display.
Insert the flat end of a spudger between the rear display bezel and the plastic rim attached to the front display bezel near the lower right corner of the display.
While carefully prying the rear display bezel away from the display assembly, use a small flathead screwdriver to pry the small steel clip nearest the bottom right corner of the display away from the edge of the front display bezel.
Repeat the above procedure until you've released all the clips along the right side of the display.
Insert the flat end of a spudger between the rear display bezel and the plastic surround of the front display bezel near the lower left corner of the display.
Carefully pry the rear display bezel away from the front display bezel to expose the metal clips along the left side of the display.
Repeat the previous procedure to release the clips along the left side of the rear display bezel.
Carefully lift the display inverter board from the side nearest the display data cable connector.
