주요 콘텐츠로 건너뛰기
PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement
필요한 것
  1. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Orient the computer so that the side with the line of screws on it is away from you.
    • Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
    • Lift the battery out of the computer.
    Which screw driver I have to use here?
    smartvideocanada - 답글
    Phillips #00 Screwdriver: All necessary tools are available to buy at the top of this page if they are needed.
    Sam Love -
  2. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement, Upper Case: 2 단계, 이미지 1/1
    • Remove the three identical Phillips screws from the memory door.
  3. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement: 3 단계, 이미지 1/1
    • Lift the memory door up enough so that you can get a grip on it, and slide it toward you, pulling it away from the casing.
  4. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement: 4 단계, 이미지 1/1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connectors. If there is a second RAM chip installed, pop it out in the same manner.
    • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side slide it a small amount (about 1/16" or 2 mm) towards the battery.
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    Where can I get a replacement clip for the ribbon cable?
    applerepairshop - 답글
    you’re a repair shop and you can’t get the connector? or have a stockpile to pull from? I could use that connector too ~
    theothertroll -
    the ribbon cable for keys and trackpad you shown are not consistent - my PB17” A1107 has just the thinner cable like one shown in prior pic~
    theothertroll - 답글
  5. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement: 6 단계, 이미지 1/1
    • For this step, you only need to move the connector about 2 mm. Pulling too hard or too far will damage the connector.
    • Loosen the trackpad connector by pulling the locking bar toward the battery housing, using the tips of your fingers.
    • Slide the trackpad cable out of the loosened connector.
    • When reattaching the trackpad ribbon cable, make sure that the orange cable is slid into the connector above the locking bar.
    • Note: When reassembling the case, the trackpad cable can get stuck below the slot to the motherboard. It's possible to nudge it out slowly by gently prodding it on either side with a small screwdriver. You don't need to use much force to do this. Eventually it will just pop back out and you can reconnect as per the instructions above. Also, note that the locking bar comes loose so if you see a little piece of plastic lying around when reassembling, that's what it is. :)
    The locking bar is UNDER the cable. It is a tiny grey (metal?) piece the width of the connector. A tiny flat head screwdriver can be handy for moving one side then another in increments towards the battery compartment. Finger nails may be too clumsy for this.
    Stan Pokras - 답글
  6. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement: 7 단계, 이미지 1/1
    • Remove the following 10 screws from the bottom case:
    • Three 1.7 mm Phillips from the front edge of the battery compartment.
    • One 3.9 mm T8 Torx to the right of the memory card.
    • One 6.9 mm T8 Torx at the left edge of the memory compartment.
    • Three 12.4 mm fully threaded Phillips from the center of the row of screws along the back edge of the case.
    • Two 15.1 mm 2.5 mm threaded Phillips, one from either end of the row of screws along the back edge of the case.
    i believe that you have the torx screws reversed here. The longer one should go on the left and vise versa.
    spatz - 답글
    oops, my bad. You're right.
    spatz - 답글
    • Turn the computer over and rotate it so that the DVI port faces you.
    • Remove the four identical Phillips screws spread along this edge of the case.
    • Turn the computer 180 degrees so that the power receptacle faces you, and remove the four Phillips screws (identical to those in the last step).
  7. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement: 10 단계, 이미지 1/1
    • Open the computer and turn it so that the screen faces you.
    • Pull the upper case off, lifting from the back, and working around the edges.
  8. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement: 11 단계, 이미지 1/1
    • Use a spudger to loosen the casing if it sticks.
    • Once the casing is entirely free, lift it off of the computer.
    BE VERY CAREFUL when replacing the keyboard to thread the keyboard ribbon cable through the slot. The steps didn't appear to make this warning and when I replaced all screws, found that it was jammed and would not come through to connect with the connector. I had to undo a lot of steps to go back and rethread it properly.
    Ted - 답글
    • The sound ribbon cable is very fragile. Be especially careful when disconnecting the cable from the logic board.
    • Disconnect both ends of the orange sound ribbon cable that crosses over the hard drive, removing tape as necessary.
    Take Care while reassembling,
    that the Trackpad-Cable does not binds under the motherboard,
    otherwise you cant connect it again on the other side.
    Til - 답글
  9. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement: 13 단계, 이미지 1/1
    • Disconnect the orange hard drive ribbon from the logic board.
  10. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement: 14 단계, 이미지 1/1
    • Remove the four T8 (lower right screw is 3.8 mm, the other 3 are 11 mm) Torx screws from the corners of the hard drive bracket.
    • Make sure you're removing the screws from the hard drive bracket, not the hard drive itself.
  11. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement: 15 단계, 이미지 1/1
    • Deroute hard drive ribbon from beneath the speaker cable.
    • Lift the hard drive and its attached cable out of the computer.
    on mine, the speaker wire was run under the IDE ribbon cable, so no rerouting was needed
    Pete - 답글
  12. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement, Hard Drive: 16 단계, 이미지 1/1
    • Your hard drive should look approximately like this.
  13. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement: 17 단계, 이미지 1/1
    • Remove the two silver Phillips screws from either side of the hard drive (four screws total).
    On mine they are tiny Torx drive screws
    John Blanning - 답글
  14. PowerBook G4 Aluminum 17" 1-1.67 GHz Hard Drive Replacement: 18 단계, 이미지 1/1
    • Disconnect the hard drive cable from the hard drive by applying even pressure on both sides while maintaining a firm grip on the drive itself.
    • This is a bit tricky. Try holding the drive against your body while pushing the cable away from you, or rocking the cable gently from side to side while applying even pressure, or both. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
    • With the label up and the pins facing away from you, the bracket that has a longer short section goes on the left side.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
결론
다른 96명이 해당 안내서를 완성하였습니다.
첨부 문서
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 2개
How to is right on the money/ Pictures, descriptions, all accurate as can be. Nicely done/
Gary Lauterback - 답글
This laptop could work with a 320 gb hard drive??
Thanks.
Javier Rodriguez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 25
30일 전: 83
전체 시간: 100,656
