이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Orient the computer so that the side with the line of screws on it is away from you.
Use your thumbs to push both battery release tabs away so that the edge of the battery lifts up.
Lift the battery out of the computer.
Lift the memory door up enough so that you can get a grip on it, and slide it toward you, pulling it away from the casing.
Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
Pull the chip directly out from its connectors. If there is a second RAM chip installed, pop it out in the same manner.
1) With your fingernails, grasp the locking bar on either side slide it a small amount (about 1/16" or 2 mm) towards the battery.
2) After disengaging the locking bar, slide the cable out of the connector.
Loosen the trackpad connector by pulling the locking bar toward the battery housing, using the tips of your fingers.
Slide the trackpad cable out of the loosened connector.
Note: When reassembling the case, the trackpad cable can get stuck below the slot to the motherboard. It's possible to nudge it out slowly by gently prodding it on either side with a small screwdriver. You don't need to use much force to do this. Eventually it will just pop back out and you can reconnect as per the instructions above. Also, note that the locking bar comes loose so if you see a little piece of plastic lying around when reassembling, that's what it is. :)
Remove the following 10 screws from the bottom case:
Three 1.7 mm Phillips from the front edge of the battery compartment.
One 3.9 mm T8 Torx to the right of the memory card.
One 6.9 mm T8 Torx at the left edge of the memory compartment.
Three 12.4 mm fully threaded Phillips from the center of the row of screws along the back edge of the case.
Two 15.1 mm 2.5 mm threaded Phillips, one from either end of the row of screws along the back edge of the case.
Turn the computer over and rotate it so that the DVI port faces you.
Remove the four identical Phillips screws spread along this edge of the case.
Turn the computer 180 degrees so that the power receptacle faces you, and remove the four Phillips screws (identical to those in the last step).
Open the computer and turn it so that the screen faces you.
Pull the upper case off, lifting from the back, and working around the edges.
Use a spudger to loosen the casing if it sticks.
Once the casing is entirely free, lift it off of the computer.
다른 5명이 해당 안내서를 완성하였습니다.
