주요 콘텐츠로 건너뛰기
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement
필요한 것
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement, Battery: 1 단계, 이미지 1/2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement, Battery: 1 단계, 이미지 2/2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement, Memory Door: 2 단계, 이미지 1/1
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 3 단계, 이미지 1/2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 3 단계, 이미지 2/2
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement, Upper Case: 4 단계, 이미지 1/1
    • Remove the following ten screws:
    • Two 14.7 mm shouldered Phillips.
    • Three 12.3 mm Phillips.
    • One 3.8 mm T8 Torx.
    • One 6.8 mm T8 Torx.
    • Three 1.3 mm Phillips.
  5. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 5 단계, 이미지 1/2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 5 단계, 이미지 2/2
    • The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
    • Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
    • The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
  6. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 6 단계, 이미지 1/1
    • Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
  7. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 7 단계, 이미지 1/1
    • Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
    • When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  8. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 8 단계, 이미지 1/1
    • Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
    • During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
  9. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 9 단계, 이미지 1/2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 9 단계, 이미지 2/2
    • Depress the display latch release button and open your display.
  10. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 10 단계, 이미지 1/2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 10 단계, 이미지 2/2
    • Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
  11. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement, Modem: 11 단계, 이미지 1/1
    • If necessary, peel back the strip of aluminum tape covering the modem cable.
  12. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 12 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the modem cable connector up off the modem.
  13. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 13 단계, 이미지 1/1
    • Disconnect the RJ-11 cable from the modem.
  14. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 14 단계, 이미지 1/1
    • Use a 4 mm nut driver to remove the two nuts securing the modem to the PC card cage.
  15. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 15 단계, 이미지 1/1
    • Lift the modem straight up off the studs on the PC card cage.
  16. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement, PC Card Cage: 16 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
    • Bend the hard drive cable away from the PC card cage, giving yourself room to remove it.
  17. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 17 단계, 이미지 1/1
    • Use the flat end of a spudger to pry the PC card cage connector up off the logic board.
  18. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 18 단계, 이미지 1/1
    • Use the tip of a spudger to peel back the small strip of copper tape off the edge of the PC card cage near the side of the lower case.
  19. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 19 단계, 이미지 1/1
    • Remove the four Phillips screws (2- 4 mm & 2 -6.8 mm ) securing the PC card cage to the lower case.
    • The two longer 6.8 mm shouldered screws belong in the end of the PC card cage closest to the logic board.
  20. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 20 단계, 이미지 1/2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 20 단계, 이미지 2/2
    • Lift the PC card cage by its center piece and maneuver it out of the lower case.
  21. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 21 단계, 이미지 1/2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) PC Card Cage Replacement: 21 단계, 이미지 2/2
    • When reinstalling your PC card cage, be sure to insert the post sticking up from the PC card release button into the hole in the black plastic release mechanism on the PC card cage.
결론
첨부 문서
Walter Galan
694,561 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 2,584
