소개
Replace a faulty PC card cage to regain functionality of your internal expansion slot.
  1. Use your thumbs to push the two battery retaining tabs away from the battery. The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. Lift the memory cover slightly and pull it toward yourself to remove it from the lower case. Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. Remove the following ten screws:
    • Remove the following ten screws:
    • Two 14.7 mm shouldered Phillips.
    • Three 12.3 mm Phillips.
    • One 3.8 mm T8 Torx.
    • One 6.8 mm T8 Torx.
    • Three 1.3 mm Phillips.
  5. The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip. Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
    • The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
    • Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
    • The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
  6. Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
    • Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
  7. Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
    • Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
    • When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  8. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  9. Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
    • Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
    • During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
  10. Depress the display latch release button and open your display. Depress the display latch release button and open your display.
    • Depress the display latch release button and open your display.
  11. Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught. Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
    • Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
  12. If necessary, peel back the strip of aluminum tape covering the modem cable.
    • If necessary, peel back the strip of aluminum tape covering the modem cable.
  13. Use the flat end of a spudger to pry the modem cable connector up off the modem.
    • Use the flat end of a spudger to pry the modem cable connector up off the modem.
  14. Disconnect the RJ-11 cable from the modem.
    • Disconnect the RJ-11 cable from the modem.
  15. Use a 4 mm nut driver to remove the two nuts securing the modem to the PC card cage.
    • Use a 4 mm nut driver to remove the two nuts securing the modem to the PC card cage.
  16. Lift the modem straight up off the studs on the PC card cage.
    • Lift the modem straight up off the studs on the PC card cage.
  17. Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
    • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
    • Bend the hard drive cable away from the PC card cage, giving yourself room to remove it.
  18. Use the flat end of a spudger to pry the PC card cage connector up off the logic board.
    • Use the flat end of a spudger to pry the PC card cage connector up off the logic board.
  19. Use the tip of a spudger to peel back the small strip of copper tape off the edge of the PC card cage near the side of the lower case.
    • Use the tip of a spudger to peel back the small strip of copper tape off the edge of the PC card cage near the side of the lower case.
  20. Remove the four Phillips screws (2- 4 mm & 2 -6.8 mm ) securing the PC card cage to the lower case.
    • Remove the four Phillips screws (2- 4 mm & 2 -6.8 mm ) securing the PC card cage to the lower case.
    • The two longer 6.8 mm shouldered screws belong in the end of the PC card cage closest to the logic board.
  21. Lift the PC card cage by its center piece and maneuver it out of the lower case. Lift the PC card cage by its center piece and maneuver it out of the lower case.
    • Lift the PC card cage by its center piece and maneuver it out of the lower case.
  22. When reinstalling your PC card cage, be sure to insert the post sticking up from the PC card release button into the hole in the black plastic release mechanism on the PC card cage. When reinstalling your PC card cage, be sure to insert the post sticking up from the PC card release button into the hole in the black plastic release mechanism on the PC card cage.
    • When reinstalling your PC card cage, be sure to insert the post sticking up from the PC card release button into the hole in the black plastic release mechanism on the PC card cage.
결론
첨부 문서
Walter Galan
592,675 평판
안내서 1,203개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,359
