소개
This guide shows the hidden screws you must remove when replacing the keyboard.
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
Where could I get a whole replacement for this connector ? Mine came off the motherboard
Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
Sometimes the "tags"/"lugs" that are around the edge of the top & bottom frame, be careful not to bend them as when putting back the covers they will not merge. I used a screwdriver to poke through the hole the screw was supposed go in & push against the "inside nut" to let the tag from the top slide down between the 2 tags. The "inside nut" is like the one right next to the ribbon cable as shown in Dia.14. The screws are from Dia. 7&8.
When putting the machine back together (following steps in reverse), make sure the trackpad ribbon cable comes through the underside of the computer — there is an opening that the cable needs to go through and you will want to “thread the needle” with the cable before securing the upper case again.
At the end of these instructions, Jimbo Combo also mentions this, but it should be repeated.
Because the trackpad/keyboard cable is part of the top face/keyboard/trackpad assembly, it’s actually a PITA when doing reassembly.
One way to make this step simple is to do the following:
1. straighten the Zif cable removing all of the bends that is probably has in it.
2. Start putting the top face/keyboard/trackpad assembly on, starting with the edge AWAY from the display.
3. Place the laptop on it’s side, and thread the cable through the opening, using tweezers if necessary so that it fully goes through the opening in the case.
4. Place the laptop back to the way it was and proceed.
ECJohansen - 답글
Remove the two Phillips screws securing the electronic track pad button to the lower case.
다른 3명이 해당 안내서를 완성하였습니다.
첨부 문서
댓글 2개
Excellent detailed instructions and cautions. Even the magnified pictures are very good. A bit more complicated than a Dell or Toshiba. Mahalo.
there’s a connector for the power button on the orange ribbon that doesn’t slip through slit - WTF?
