주요 콘텐츠로 건너뛰기
PowerBook G4 Titanium DVI DC-In Board Replacement
필요한 것
  1. PowerBook G4 Titanium DVI DC-In Board Replacement, Battery: 1 단계, 이미지 2개 중 1개 PowerBook G4 Titanium DVI DC-In Board Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI DC-In Board Replacement, Lower Case: 2 단계, 이미지 2개 중 1개 PowerBook G4 Titanium DVI DC-In Board Replacement, Lower Case: 2 단계, 이미지 2개 중 2개
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. PowerBook G4 Titanium DVI DC-In Board Replacement, DC-In Board: 3 단계, 이미지 1개 중 1개
    • Disconnect the large DC-In connector from the right side of the logic board.
  4. PowerBook G4 Titanium DVI DC-In Board Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the two T6 Torx screws from the DC-In board.
  5. PowerBook G4 Titanium DVI DC-In Board Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the DC-In board out of the computer by pulling up and away from you.
    • If you don't have a 667 MHz computer, there is a fan in this location which makes it a bit difficult to remove the DC-In board.
    • If there is a fan present, rotate the DC-In board slightly clockwise before easing it out at a slight angle in order to clear the fan clamp on top of it.
결론
다른 4명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
5다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 635개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 15,674
