주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Locate the battery release tab on the underside of the G4. Slide the battery release tab to the left and lift the battery out of the computer.
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the seven T8 Torx screws from the lower case. Using your thumbs, slide the lower case toward the front of the computer.
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Disconnect the large DC-In connector from the right side of the logic board.
    • Disconnect the large DC-In connector from the right side of the logic board.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the two T6 Torx screws from the DC-In board.
    • Remove the two T6 Torx screws from the DC-In board.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Lift the DC-In board out of the computer by pulling up and away from you.
    • Lift the DC-In board out of the computer by pulling up and away from you.
    • If you don't have a 667 MHz computer, there is a fan in this location which makes it a bit difficult to remove the DC-In board.
    • If there is a fan present, rotate the DC-In board slightly clockwise before easing it out at a slight angle in order to clear the fan clamp on top of it.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
첨부 문서
iRobot
회원 가입일: 2009년 09월 24일
1 평판
안내서 648개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 14,926
