주요 콘텐츠로 건너뛰기
PowerBook G4 Titanium Mercury Lower Case Replacement
필요한 것
    • Turn the G4 over.
    • Remove the eight Phillips screws from the lower case.
  1. PowerBook G4 Titanium Mercury Lower Case Replacement: 2 단계, 이미지 1/1
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  2. PowerBook G4 Titanium Mercury Lower Case Replacement: 3 단계, 이미지 1/1
    • Your laptop should look approximately like this.
결론
첨부 문서
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 5,259
