이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Change out the entire display assembly, including the hinges and casing. This installation is MUCH easier than replacing just the LCD panel.
필요한 것
Remove the battery.
Turn the keyboard locking screw so that it is parallel to the space bar.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out. Place the computer on the cloth.
Turn the G4 over.
Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
Open the display to a 90 degree angle. Rest the trackpad face down on the work surface and allow the display to hang over the edge. If possible, adjust your chair or work surface height so the display will rest on your legs and the trackpad will lie flat on the work surface.
Remove the four T8 Torx screws that fasten the display to the trackpad. The screw closest to the display data cable has a tapered head.
다른 9명이 해당 안내서를 완성하였습니다.
