주요 콘텐츠로 건너뛰기
PowerLead Puto PLD003 Screen Replacement
필요한 것
  1. PowerLead Puto PLD003 Screen Replacement, Side Panel: 1 단계, 이미지 1개 중 1개
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Screen Replacement, Screen: 5 단계, 이미지 2개 중 1개 PowerLead Puto PLD003 Screen Replacement, Screen: 5 단계, 이미지 2개 중 2개
    • Remove the three 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the back panel away from the camera by applying pressure to it.
  8. PowerLead Puto PLD003 Screen Replacement: 8 단계, 이미지 2개 중 1개 PowerLead Puto PLD003 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Set aside back panel for now.
    • Remove the final 4 mm Phillips #1 screw holding the screen in place. It is very small and hard to see.
  9. PowerLead Puto PLD003 Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Carefully apply pressure, away from the camera, to the screen to detach it from the body.
    • The white cord should still be connected to the body.
  10. PowerLead Puto PLD003 Screen Replacement: 10 단계, 이미지 2개 중 1개 PowerLead Puto PLD003 Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Lift the black clip upward.
    • With the clip up, pull the white cord to the left. This will detach the screen from the body.
결론
작성자
3다른 기여자 명과 함께
Justin Tew
회원 가입일: 03/31/16
767 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 311
