주요 콘텐츠로 건너뛰기
PowerLead Puto PLD003 Tripod Clip Replacement
필요한 것
  1. PowerLead Puto PLD003 Tripod Clip Replacement, Side Panel: 1 단계, 이미지 1/1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Tripod Clip Replacement: 2 단계, 이미지 1/1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Tripod Clip Replacement: 3 단계, 이미지 1/1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Tripod Clip Replacement: 4 단계, 이미지 1/1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: 5 단계, 이미지 1/2 PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: 5 단계, 이미지 2/2
    • Apply pressure upwards to remove the tripod clip.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Justin Tew
회원 가입일: 03/31/16
767 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 135
