이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Removing the graphics card.
필요한 것
Pull on outer latch.
Lower door until it is level with your work surface.
Remove the single screw with the Phillips #1 screwdriver.
Pull the graphics card up and out.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 2개
Do I need to avoid static to protect the board?
Jim Robson - 답글
Es ist eine deutsche Anleitung, aber auf der iFixit Übersicht als Englisch gekennzeichnet.
