주요 콘텐츠로 건너뛰기
PowerShot G7 X Mark II Battery Replacement
  1. PowerShot G7 X Mark II Battery Replacement, Battery: 1 단계, 이미지 1/2 PowerShot G7 X Mark II Battery Replacement, Battery: 1 단계, 이미지 2/2
    • On the bottom of the camera, slide the latch on the battery cover toward the center of the camera.
    • The spring-loaded battery door will open revealing the battery inside.
  2. PowerShot G7 X Mark II Battery Replacement: 2 단계, 이미지 1/2 PowerShot G7 X Mark II Battery Replacement: 2 단계, 이미지 2/2
    • Move the latch from the top of the battery to release it.
    • The battery is spring loaded and should pop out from the compartment.
결론
Brandon
회원 가입일: 02/15/17
626 평판
안내서 4개 작성하였습니다
USF Tampa, Team 12-3, Eyestone Spring 2017 USF Tampa, Team 12-3, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G3
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 28
전체 시간: 2,269
