주요 콘텐츠로 건너뛰기
PowerShot G7 X Mark II Front Cover Replacement
필요한 것
  1. PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: 1 단계, 이미지 1/2 PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: 1 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
  2. PowerShot G7 X Mark II Front Cover Replacement: 2 단계, 이미지 1/2 PowerShot G7 X Mark II Front Cover Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove five screws from under the LCD screen:
    • Three 2.4 mm screws
    • Two 3 mm screws
  3. PowerShot G7 X Mark II Front Cover Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left of the camera.
  4. PowerShot G7 X Mark II Front Cover Replacement: 4 단계, 이미지 1/2 PowerShot G7 X Mark II Front Cover Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
  5. PowerShot G7 X Mark II Front Cover Replacement: 5 단계, 이미지 1/2 PowerShot G7 X Mark II Front Cover Replacement: 5 단계, 이미지 2/2
    • Carefully remove the back cover off of the camera by hand, minding the ribbon cable attached to the camera body. If the cover does not detach, use a spudger to pry it off.
    • Use the spudger tool to open the ZIF connector attaching the ribbon cable to the camera body.
  6. PowerShot G7 X Mark II Front Cover Replacement: 6 단계, 이미지 1/2 PowerShot G7 X Mark II Front Cover Replacement: 6 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
  7. PowerShot G7 X Mark II Front Cover Replacement: 7 단계, 이미지 1/2 PowerShot G7 X Mark II Front Cover Replacement: 7 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
    • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
  8. PowerShot G7 X Mark II Front Cover Replacement: 8 단계, 이미지 1/3 PowerShot G7 X Mark II Front Cover Replacement: 8 단계, 이미지 2/3 PowerShot G7 X Mark II Front Cover Replacement: 8 단계, 이미지 3/3
    • Open the battery compartment and remove the battery by flipping the small latch holding it in.
    • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
  9. PowerShot G7 X Mark II Front Cover Replacement: 9 단계, 이미지 1/2 PowerShot G7 X Mark II Front Cover Replacement: 9 단계, 이미지 2/2
    • Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
  10. PowerShot G7 X Mark II Front Cover Replacement, Front Cover: 10 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
  11. PowerShot G7 X Mark II Front Cover Replacement: 11 단계, 이미지 1/1
    • Remove the USB/HDMI panel from the right side of the camera.
  12. PowerShot G7 X Mark II Front Cover Replacement: 12 단계, 이미지 1/1
    • Separate the front cover and focus ring assembly from the front of the camera. Use a plastic spudger to detach the ZIF connector holding the ribbon cable connected to the focus assembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brandon
회원 가입일: 02/15/17
626 평판
안내서 4개 작성하였습니다
USF Tampa, Team 12-3, Eyestone Spring 2017 USF Tampa, Team 12-3, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G3
3 회원들
안내서 4개 작성하였습니다
댓글 2개
thank you so much for the guide!! extremely helpful, clear pictures, and easy to understand instructions.
victoria - 답글
Please give instructions how to disassemble the flash and replace the flash capacitor. Thank you very much
Momchil Panayotov - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 43
전체 시간: 3,973
