소개
This guide will outline the steps involved in replacing the main board of an iHome iP37
필요한 것
이 단계에 사용된 도구:iOpener$19.99
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
Lift and remove the counterweight.
Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
다른 한 분이 해당 안내서를 완성하였습니다.
