주요 콘텐츠로 건너뛰기
Presidential 2.0 Power Box Cover Removal
필요한 것
  1. Presidential 2.0 Power Box Cover Removal, Removing the Screws: 1 단계, 이미지 1개 중 1개
    • First remove the 2 Phillips head screws on the front of the power cover.
    • BEWARE : this may be more difficult if on carpet and may require another person to push the chair off the floor.
  2. Presidential 2.0 Power Box Cover Removal: 2 단계, 이미지 3개 중 1개 Presidential 2.0 Power Box Cover Removal: 2 단계, 이미지 3개 중 2개 Presidential 2.0 Power Box Cover Removal: 2 단계, 이미지 3개 중 3개
    • Using a Philips head screw driver preferable Size 1 , remove the 5 screws.
    • Once all screws are removed , Place your hands where the red rectangles are marked, Place your fingers under the lip of that cover and give a slight pull upwards.
    • Take Care when removing this cover as there is a wire running across it.
  3. Presidential 2.0 Power Box Cover Removal: 3 단계, 이미지 1개 중 1개
    • You're Done !
결론
To reassemble your device, follow these instructions in reverse order. Be sure you are snapping the ball and joint pieces back together when your are reassembling .
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nick
회원 가입일: 05/30/17
2,764 평판
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 108
