소개
Follow this guide to remove or replace the pump on your Presto Carpet Extractor 9.840-068.0 (2016).
Be sure to thoroughly clean and dry your extractor before you begin.
필요한 것
If it is still attached, pull and disconnect the brass quick-connect fitting from the carpet extractor body.
Unclasp and release the two black latches on either side of the carpet extractor.
Use a Phillips #3 screwdriver to remove the two 1-1/2" screws and washers securing the pump housing.
Tilt the vacuum motor and pump housing sideways and let it rest on the side of the extractor.
Use a Phillips #2 screwdriver to remove the two 1/2" screws and star washers securing the pump mounting bracket.
Twist the pump body counterclockwise until it is disconnected from the fitting at the other end of pump.
Remove the pump from the extractor.
Use a pair of pliers to unscrew and remove the remaining brass fitting from the pump.
다른 6명이 해당 안내서를 완성하였습니다.
