주요 콘텐츠로 건너뛰기
Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement
필요한 것
  1. Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Disconnect the Hose: 1 단계, 이미지 3개 중 1개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Disconnect the Hose: 1 단계, 이미지 3개 중 2개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Disconnect the Hose: 1 단계, 이미지 3개 중 3개
    • Ensure your carpet extractor is unplugged and switched off before starting this procedure.
    • If it is still attached, pull and disconnect the brass quick-connect fitting from the carpet extractor body.
  2. Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement: 2 단계, 이미지 2개 중 1개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement: 2 단계, 이미지 2개 중 2개
    • If it is still attached, disconnect the black hose from the recovery tank.
  3. Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Remove the Recovery Tank: 3 단계, 이미지 3개 중 1개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Remove the Recovery Tank: 3 단계, 이미지 3개 중 2개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Remove the Recovery Tank: 3 단계, 이미지 3개 중 3개
    • Unclasp and release the two black latches on either side of the carpet extractor.
  4. Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement: 4 단계, 이미지 2개 중 1개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the recovery tank.
  5. Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Remove the Vacuum Motor Retainer: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #2 screwdriver to remove the two 1/2" screws and washers securing the vacuum motor retainer.
  6. Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement: 6 단계, 이미지 2개 중 1개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the vacuum motor cover, retainer, and gasket as one piece.
  7. Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Disconnect the Vacuum Motor: 7 단계, 이미지 3개 중 1개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Disconnect the Vacuum Motor: 7 단계, 이미지 3개 중 2개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Disconnect the Vacuum Motor: 7 단계, 이미지 3개 중 3개
    • Gently pull the vacuum motor up and out of the extractor housing and lay it on its side.
    • Do not completely remove the motor, as it's still connected to the carpet extractor.
    • During reassembly, insert the side of the motor connected to the wires first, then carefully drop the other side into place.
  8. Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement: 8 단계, 이미지 1개 중 1개
    • Use a Phillips #2 Screwdriver to remove the 3/8" terminal screw securing the motor's three ground wires.
    • During reassembly, ensure all three of these wires are reconnected to this screw terminal. The order in which they are stacked does not matter.
  9. Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement: 9 단계, 이미지 2개 중 1개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement: 9 단계, 이미지 2개 중 2개
    • Use a pair of wire cutters or scissors to cut and remove the zip tie secured around the black, yellow, and green motor wires.
    • Take note of where this zip tie is located so it can be replaced during reassembly. If the cables inside the housing aren't managed properly, the vacuum motor will not fit back inside the housing.
  10. Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement: 10 단계, 이미지 3개 중 1개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement: 10 단계, 이미지 3개 중 2개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement: 10 단계, 이미지 3개 중 3개
    • Disconnect the two black motor wires from the switch mounted inside the carpet extractor housing.
    • This may require a significant amount of force; pull and wiggle the connector until it is free.
    • Do not worry about which wire is connected to which connector, as the motor's polarity does not matter.
  11. Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Remove the Vacuum Motor: 11 단계, 이미지 1개 중 1개
    • Remove the vacuum motor.
  12. Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Crimp the New Wire Terminals: 12 단계, 이미지 3개 중 1개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Crimp the New Wire Terminals: 12 단계, 이미지 3개 중 2개 Presto Carpet Extractor 9.840-068.0 2016 Vacuum Motor Replacement, Crimp the New Wire Terminals: 12 단계, 이미지 3개 중 3개
    • If your replacement vacuum motor does not have quick disconnects on the end of its wires, strip about half an inch of insulation off of each wire to install new crimp connectors.
    • Once the wires are stripped, install new 14-16 AWG insulated female crimp connectors onto the bare wire ends. Use a crimping tool to secure them.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tarun Thiruma
회원 가입일: 11/20/19
39,444 평판
안내서 134개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 29
지난 30일: 63
전체 시간: 4,350
