소개
Follow this guide to remove or replace the vacuum motor on your Presto Carpet Extractor 9.840-068.0 (2016).
Be sure to thoroughly clean and dry your extractor before you begin.
필요한 것
If it is still attached, pull and disconnect the brass quick-connect fitting from the carpet extractor body.
Unclasp and release the two black latches on either side of the carpet extractor.
Use a Phillips #2 screwdriver to remove the two 1/2" screws and washers securing the vacuum motor retainer.
Gently pull the vacuum motor up and out of the extractor housing and lay it on its side.
다른 5명이 해당 안내서를 완성하였습니다.
