주요 콘텐츠로 건너뛰기
Presto PopLite 04820 Motor Replacement
필요한 것
  1. Presto PopLite 04820 Motor Replacement, Baseplate: 1 단계, 이미지 1/1
    • Be sure that the popper is unplugged before disassembly.
    • Turn Presto Popper upside down.
  2. Presto PopLite 04820 Motor Replacement: 2 단계, 이미지 1/3 Presto PopLite 04820 Motor Replacement: 2 단계, 이미지 2/3 Presto PopLite 04820 Motor Replacement: 2 단계, 이미지 3/3
    • Remove the four 9 mm Phillips #2 screws from the base.
    • Once all four screws are removed, take the base off.
  3. Presto PopLite 04820 Motor Replacement, Motor: 3 단계, 이미지 1/2 Presto PopLite 04820 Motor Replacement, Motor: 3 단계, 이미지 2/2
    • Unscrew the four 13mm Phillips #2 screws but do not remove completely just yet.
  4. Presto PopLite 04820 Motor Replacement: 4 단계, 이미지 1/2 Presto PopLite 04820 Motor Replacement: 4 단계, 이미지 2/2
    • Locate the two twist-on wire connectors.
    • Unscrew the two caps and keep track of the wires that wire up together to make it easier in the end to put back together.
  5. Presto PopLite 04820 Motor Replacement: 5 단계, 이미지 1/3 Presto PopLite 04820 Motor Replacement: 5 단계, 이미지 2/3 Presto PopLite 04820 Motor Replacement: 5 단계, 이미지 3/3
    • Pull the entire cavity out of the popper that holds the motor.
    • Remove the popping chamber base.
  6. Presto PopLite 04820 Motor Replacement: 6 단계, 이미지 1/2 Presto PopLite 04820 Motor Replacement: 6 단계, 이미지 2/2
    • Remove circuit board from the motor base holder.
    • Make sure these 3 wires are securely placed inside grooves when reassembling the motor base holder.
  7. Presto PopLite 04820 Motor Replacement: 7 단계, 이미지 1/2 Presto PopLite 04820 Motor Replacement: 7 단계, 이미지 2/2
    • Remove the orange twist-on wire connector connecting the black wire to the grey wire.
  8. Presto PopLite 04820 Motor Replacement: 8 단계, 이미지 1/2 Presto PopLite 04820 Motor Replacement: 8 단계, 이미지 2/2
    • Locate the clear plastic motor fan.
    • Grab hold of the motor and pull upwards to pop the motor fan off of the needle that connects to the motor.
    • This may require large amounts of force to pull it off the needle.
  9. Presto PopLite 04820 Motor Replacement: 9 단계, 이미지 1/3 Presto PopLite 04820 Motor Replacement: 9 단계, 이미지 2/3 Presto PopLite 04820 Motor Replacement: 9 단계, 이미지 3/3
    • Remove the two 4 mm Phillips #00 screws.
    • Once the screws are removed, the motor should drop down.
    • Now remove the motor base to expose the motor.
  10. Presto PopLite 04820 Motor Replacement: 10 단계, 이미지 1/2 Presto PopLite 04820 Motor Replacement: 10 단계, 이미지 2/2
    • This is the motor.
    • Now replace it with your new one!
결론
다른 4명이 해당 안내서를 완성하였습니다.
Emanuele Rocco
회원 가입일: 08/27/15
694 평판
안내서 6개 작성하였습니다
USF Tampa, Team 2-5, Blackwell Fall 2015 USF Tampa, Team 2-5, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G5
2 회원들
안내서 6개 작성하였습니다
댓글 한 개
What new motor? Where do we get said motor, and what are the motor specs? What about installing the bridge rectifier on the new motor? A 3rd party supplier is not likely to sell these motors with the rectifier pre-installed.
Bill Richardson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 2,615
