주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Replace the electric motor that powers the fan and creates hot air to pop the kernels. The motor is essential to the use of the Presto PopLite 04820. Overtime the motor may burn out and need to be replaced. Be sure that the PopLite is unplugged from the wall and has had time after use to cool down before working on it.
부품
지정된 부품이 없습니다.
  1. Be sure that the popper is unplugged before disassembly.
    • Be sure that the popper is unplugged before disassembly.
    • Turn Presto Popper upside down.
  2. Remove the four 9 mm Phillips #2  screws from the base. Once all four screws are removed, take the base off. Once all four screws are removed, take the base off.
    • Remove the four 9 mm Phillips #2 screws from the base.
    • Once all four screws are removed, take the base off.
  3. Unscrew the four 13mm Phillips #2 screws but do not remove completely just yet. Unscrew the four 13mm Phillips #2 screws but do not remove completely just yet.
    • Unscrew the four 13mm Phillips #2 screws but do not remove completely just yet.
  4. Locate the two twist-on wire connectors. Unscrew the two caps and keep track of the wires that wire up together to make it easier in the end to put back together.
    • Locate the two twist-on wire connectors.
    • Unscrew the two caps and keep track of the wires that wire up together to make it easier in the end to put back together.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Pull the entire cavity out of the popper that holds the motor. Remove the popping chamber base. Remove the popping chamber base.
    • Pull the entire cavity out of the popper that holds the motor.
    • Remove the popping chamber base.
  7. Remove circuit board from the motor base holder. Make sure these 3 wires are securely placed inside grooves when reassembling the motor base holder.
    • Remove circuit board from the motor base holder.
    • Make sure these 3 wires are securely placed inside grooves when reassembling the motor base holder.
  8. Remove the orange twist-on wire connector connecting the black wire to the grey wire. Remove the orange twist-on wire connector connecting the black wire to the grey wire.
    • Remove the orange twist-on wire connector connecting the black wire to the grey wire.
  9. Locate the clear plastic motor fan. Grab hold of the motor and pull upwards to pop the motor fan off of the needle that connects to the motor.
    • Locate the clear plastic motor fan.
    • Grab hold of the motor and pull upwards to pop the motor fan off of the needle that connects to the motor.
    • This may require large amounts of force to pull it off the needle.
  10. Remove the two 4 mm Phillips #00 screws. Once the screws are removed, the motor should drop down. Now remove the motor base to expose the motor.
    • Remove the two 4 mm Phillips #00 screws.
    • Once the screws are removed, the motor should drop down.
    • Now remove the motor base to expose the motor.
  11. This is the motor. Now replace it with your new one!
    • This is the motor.
    • Now replace it with your new one!
결론
다른 3명이 해당 안내서를 완성하였습니다.
Emanuele Rocco
회원 가입일: 2015년 08월 27일
670 평판
안내서 6개 작성하였습니다
USF Tampa, Team 2-5, Blackwell Fall 2015 USF Tampa, Team 2-5, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G5
2 회원들
안내서 6개 작성하였습니다
What new motor? Where do we get said motor, and what are the motor specs? What about installing the bridge rectifier on the new motor? A 3rd party supplier is not likely to sell these motors with the rectifier pre-installed.
Bill Richardson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 33
전체 시간: 1,497
