이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the four 9 mm Phillips #2 screws from the base.
Once all four screws are removed, take the base off.
Unscrew the four 13mm Phillips #2 screws but do not remove completely just yet.
Locate the two twist-on wire connectors.
Unscrew the two caps and keep track of the wires that wire up together to make it easier in the end to put back together.
Pull the entire cavity out of the popper that holds the motor.
Remove the popping chamber base.
Remove circuit board from the motor base holder.
Make sure these 3 wires are securely placed inside grooves when reassembling the motor base holder.
Remove the orange twist-on wire connector connecting the black wire to the grey wire.
Locate the clear plastic motor fan.
Grab hold of the motor and pull upwards to pop the motor fan off of the needle that connects to the motor.
Remove the two 4 mm Phillips #00 screws.
Now remove the motor base to expose the motor.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
What new motor? Where do we get said motor, and what are the motor specs? What about installing the bridge rectifier on the new motor? A 3rd party supplier is not likely to sell these motors with the rectifier pre-installed.
