주요 콘텐츠로 건너뛰기
Presto PopLite 04820 Popping Chamber Base Replacement
필요한 것
  1. Presto PopLite 04820 Popping Chamber Base Replacement, Baseplate: 1 단계, 이미지 1/1
    • Be sure that the popper is unplugged before disassembly.
    • Turn Presto Popper upside down.
  2. Presto PopLite 04820 Popping Chamber Base Replacement: 2 단계, 이미지 1/3 Presto PopLite 04820 Popping Chamber Base Replacement: 2 단계, 이미지 2/3 Presto PopLite 04820 Popping Chamber Base Replacement: 2 단계, 이미지 3/3
    • Remove the four 9 mm Phillips #2 screws from the base.
    • Once all four screws are removed, take the base off.
  3. Presto PopLite 04820 Popping Chamber Base Replacement, Popping Chamber Base: 3 단계, 이미지 1/2 Presto PopLite 04820 Popping Chamber Base Replacement, Popping Chamber Base: 3 단계, 이미지 2/2
    • Remove the four 13 mm Phillips #2 screws.
  4. Presto PopLite 04820 Popping Chamber Base Replacement: 4 단계, 이미지 1/1
    • Remove the entire cavity that holds the motor from the base of the PopLite.
    • Be gentle while taking the motor out of the base to avoid wire damage.
  5. Presto PopLite 04820 Popping Chamber Base Replacement: 5 단계, 이미지 1/2 Presto PopLite 04820 Popping Chamber Base Replacement: 5 단계, 이미지 2/2
    • Turn the popping chamber base sideways.
    • Now remove popping chamber base.
결론
Emanuele Rocco
회원 가입일: 08/27/15
694 평판
안내서 6개 작성하였습니다
USF Tampa, Team 2-5, Blackwell Fall 2015 USF Tampa, Team 2-5, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G5
2 회원들
안내서 6개 작성하였습니다
댓글 한 개
Where can I get the new base from?
Barry - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 638
