주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide shows how to replace the Presto PopLite 04820 Popping Chamber base. The Popping Chamber Base may need to be replaced if it has been coated with any popcorn residue that is permanent. Be sure that the PopLite is unplugged from the wall and has had time after use to cool down before working on the device.
부품
지정된 부품이 없습니다.
  1. Be sure that the popper is unplugged before disassembly.
    • Be sure that the popper is unplugged before disassembly.
    • Turn Presto Popper upside down.
  2. Remove the four 9 mm Phillips #2  screws from the base. Once all four screws are removed, take the base off. Once all four screws are removed, take the base off.
    • Remove the four 9 mm Phillips #2 screws from the base.
    • Once all four screws are removed, take the base off.
  3. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  4. Remove the four 13 mm Phillips #2 screws. Remove the four 13 mm Phillips #2 screws.
    • Remove the four 13 mm Phillips #2 screws.
  5. Remove the entire cavity that holds the motor from the base of the PopLite.
    • Remove the entire cavity that holds the motor from the base of the PopLite.
    • Be gentle while taking the motor out of the base to avoid wire damage.
  6. Turn the popping chamber base sideways. Now remove popping chamber base.
    • Turn the popping chamber base sideways.
    • Now remove popping chamber base.
결론
Emanuele Rocco
회원 가입일: 2015년 08월 27일
670 평판
안내서 6개 작성하였습니다
USF Tampa, Team 2-5, Blackwell Fall 2015 USF Tampa, Team 2-5, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G5
2 회원들
안내서 6개 작성하였습니다
Where can I get the new base from?
Barry - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 376
