주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Shows how to replace the entire power cord. This may need to be done if the device shut off mid-use. Be sure that the PopLite is unplugged from the wall and has had time after use to cool down before working on the device.
부품
지정된 부품이 없습니다.
  1. Be sure that the popper is unplugged before disassembly.
    • Be sure that the popper is unplugged before disassembly.
    • Turn Presto Popper upside down.
  2. Remove the four 9 mm Phillips #2  screws from the base. Once all four screws are removed, take the base off. Once all four screws are removed, take the base off.
    • Remove the four 9 mm Phillips #2 screws from the base.
    • Once all four screws are removed, take the base off.
  3. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  4. Untwist the two orange twist-on wire connectors. Make a note of which wires are in each of the orange caps. Make a note of which wires are in each of the orange caps.
    • Untwist the two orange twist-on wire connectors.
    • Make a note of which wires are in each of the orange caps.
  5. Locate the plastic piece holding the power cord in place. Take the metal spudger from the tool kit and pry this piece loose. This plastic piece may take excessive force to pry out, just keep trying until it pops out.
    • Locate the plastic piece holding the power cord in place.
    • Take the metal spudger from the tool kit and pry this piece loose.
    • This plastic piece may take excessive force to pry out, just keep trying until it pops out.
    • Remove the power cord.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Emanuele Rocco
회원 가입일: 2015년 08월 27일
670 평판
안내서 6개 작성하였습니다
USF Tampa, Team 2-5, Blackwell Fall 2015 USF Tampa, Team 2-5, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G5
2 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 282
