주요 콘텐츠로 건너뛰기
Presto Stirring Popper 0520002 Base Replacement
필요한 것
  1. Presto Stirring Popper 0520002 Base Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Detach the cover/serving bowl from the popper.
    • Flip the base of the popper over and remove the four 14 mm Phillips #2 screws attaching the bottom cover to the base.
  2. Presto Stirring Popper 0520002 Base Replacement: 2 단계, 이미지 1/2 Presto Stirring Popper 0520002 Base Replacement: 2 단계, 이미지 2/2
    • Removing the bottom cover exposes the internals of the popper. The base holds together the centrally mounted motor and the wires for the power cord and heating element.
  3. Presto Stirring Popper 0520002 Base Replacement, Motor: 3 단계, 이미지 1/3 Presto Stirring Popper 0520002 Base Replacement, Motor: 3 단계, 이미지 2/3 Presto Stirring Popper 0520002 Base Replacement, Motor: 3 단계, 이미지 3/3
    • Remove the two black wire twist caps, and unwind the different wires.
    • During reassembly, make sure the wires are strongly twisted together (twist clockwise) and the wire caps are firmly attached.
    • Avoid swapping the polarity during reassembly. The neutral (ridged) wire connects to the left motor wire and the white wire to the heater.
    • Remove two more 14 mm Phillips #2 screws attaching the white plastic holding the wall cord to the base.
  4. Presto Stirring Popper 0520002 Base Replacement: 4 단계, 이미지 1/3 Presto Stirring Popper 0520002 Base Replacement: 4 단계, 이미지 2/3 Presto Stirring Popper 0520002 Base Replacement: 4 단계, 이미지 3/3
    • Remove the two 14 mm Phillips #2 screws from the motor.
    • Remove the motor from the popper.
    • A spring located in the shaft may force the motor out when the screws are sufficiently loosened.
  5. Presto Stirring Popper 0520002 Base Replacement, Base: 5 단계, 이미지 1/1
    • Remove the four 50 mm screws attaching the base to the heating pan.
    • Removing these screws takes significant force.
  6. Presto Stirring Popper 0520002 Base Replacement: 6 단계, 이미지 1/1
    • Remove the base from the rest of the device.
결론
Kristen Gismondi
회원 가입일: 11/12/14
82,698 평판
안내서 202개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,430개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 105
