주요 콘텐츠로 건너뛰기
소개
This guide provides the necessary information on fully disassembling the Proline HB25 hand blender.
  1. Unscrew the screw on the back of the product.
    • Unscrew the screw on the back of the product.
  2. Pull out the backtab of the housing. Push in the snapfits with, for instance, a screwdriver.
    • Pull out the backtab of the housing.
    • Push in the snapfits with, for instance, a screwdriver.
  3. Separate the housing with calibrated force. Keep your fingers away from the housing and do not bend or break the housing.
    • Separate the housing with calibrated force.
    • Keep your fingers away from the housing and do not bend or break the housing.
    • Use a flathead screwdriver to push out the lower function button.
    • Remove the separating device.
  4. 안드로이드 수리 키트
    A new screen or battery is one kit away.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  5. Unscrew the hidden screw under the button.
    • Unscrew the hidden screw under the button.
  6. Open the housing. Unscrew the circuit board.
    • Open the housing.
    • Unscrew the circuit board.
    • Unscrew the wire lock.
  7. Push the housing of the button out of the housing. Push the housing of the button out of the housing.
    • Push the housing of the button out of the housing.
  8. Push on the side of the housing of the button to push the button out of the housing. The spring can jump away when you push out the button.
    • Push on the side of the housing of the button to push the button out of the housing.
    • The spring can jump away when you push out the button.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jorma van Dalen
회원 가입일: 2018년 03월 07일
175 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 56
