주요 콘텐츠로 건너뛰기
ProScan PLT7050 Motherboard Replacement
필요한 것
  1. ProScan PLT7050 Motherboard Replacement, Open Device: 1 단계, 이미지 1개 중 1개
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  2. ProScan PLT7050 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
  3. ProScan PLT7050 Motherboard Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 ProScan PLT7050 Motherboard Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Remove the 3 black pieces of tape from the device.
    • Remove the 5 yellow pieces of tape from the device.
  4. ProScan PLT7050 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 ProScan PLT7050 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use the soldering tool to remove the 3 wires from the mother board to the battery (black, red, gray).
    • Soldering tool will get hot.
  5. ProScan PLT7050 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 ProScan PLT7050 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the speaker wires from the motherboard with the soldering tool.
  6. ProScan PLT7050 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove 3 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  7. ProScan PLT7050 Motherboard Replacement: 7 단계, 이미지 3개 중 1개 ProScan PLT7050 Motherboard Replacement: 7 단계, 이미지 3개 중 2개 ProScan PLT7050 Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to pop open all 3 ZIF connector tabs connected to the motherboard.
    • Remove each ribbon from the ZIF connector port.
  8. ProScan PLT7050 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the motherboard off the device taking care to pull the ports out of the casing.
결론
작성자
2다른 기여자 명과 함께
Valerie Landguth
회원 가입일: 01/19/17
320 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 447
