주요 콘텐츠로 건너뛰기
ProScan PLT7050 Speaker Replacement
필요한 것
  1. ProScan PLT7050 Speaker Replacement, Open Device: 1 단계, 이미지 1개 중 1개
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  2. ProScan PLT7050 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
  3. ProScan PLT7050 Speaker Replacement, Speaker: 3 단계, 이미지 1개 중 1개
    • Remove the yellow tape.
  4. ProScan PLT7050 Speaker Replacement: 4 단계, 이미지 2개 중 1개 ProScan PLT7050 Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Use the soldering tool to remove the two speaker wires from the mother board.
    • Take note of where the wires are located.
    • Soldering tool will get hot.
결론
작성자
4다른 기여자 명과 함께
Jazmine Jackson
회원 가입일: 01/19/17
284 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 245
