주요 콘텐츠로 건너뛰기
Problem with navigation in the Android System Recovery menu
동영상 개요
  1. Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: 1 단계, 이미지 1/3 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: 1 단계, 이미지 2/3 Problem with navigation in the Android System Recovery menu, Problem with navigation in the Android System Recovery menu: 1 단계, 이미지 3/3
    • Open the Android System Recovery menu.
    • You can find the manual how to do this here.
    • If your tablet is stuck on the Android robot with exclamation mark picture, press the Volume Up or Down button.
    • Now, if the cursor is on "reboot system now", press the Volume Down key twice to go to "apply update from external storage", and just once to go to "wipe data...".
    • The cursor will stay on "apply update..." but the real selection will be "wipe data / factory reset".
    • Press the Power On button to select it. In the next menu you must choose "Yes - erase all user data".
    • Use the same technique to choose it. And finally, "reboot system now".
  2. Problem with navigation in the Android System Recovery menu: 2 단계, 이미지 1/2 Problem with navigation in the Android System Recovery menu: 2 단계, 이미지 2/2
    • If the cursor is on "Apply update from ADB", press the Volume Down key twice to go to "wipe data/factory reset" and choose it with the Power On button.
    • On the next screen press press the Volume Down 3x to go steb before "Yes --delete all user data".
    • Press another one time the Volume down button. The cursor will not move, but actually you are on the "Yes -- delete all user data" and you can select it with the Power On button.
    • Did you do it successfully?
결론
다른 35명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,882 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,516개 작성하였습니다
댓글 13개
When i factory reset through the Android system recovery menu, i can't navigate normally.
I fix it now,thank you very much!
AndroidDataRecovery - 답글
Fix all data. System
Macky Villanueva -
I can't do it it just does up with a different thing
irirangihammond - 답글
Wow I did not know this.ill try this way and thanks for the benifit
issammax147 - 답글
I got to the page where I gave to select yes but it jumps 2 spaces up and down and jumps past the yes option. How can I do it
Brittany - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 64
전체 시간: 74,403
