소개
In this guide we will open up the toaster and remove the old faulty power cord.
필요한 것
Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
Remove the small circuit board by pulling on the two side tabs while simultaneously releasing the middle clip.
Slide the small circuit board out of it's clips.
다른 한 분이 해당 안내서를 완성하였습니다.
