주요 콘텐츠로 건너뛰기
Projector - Vivitek D855ST DMD Chip Board Replacement
필요한 것
  1. Projector - Vivitek D855ST DMD Chip Board Replacement, Chip Board: 1 단계, 이미지 3개 중 1개 Projector - Vivitek D855ST DMD Chip Board Replacement, Chip Board: 1 단계, 이미지 3개 중 2개 Projector - Vivitek D855ST DMD Chip Board Replacement, Chip Board: 1 단계, 이미지 3개 중 3개
    • First grab a 00 Phillips screwdriver remove the lamp cover.
    • Then loosen the 3 captive screws holding the lamp in the projector with a standard Phillips screwdriver.
  2. Projector - Vivitek D855ST DMD Chip Board Replacement, Remove the housing: 2 단계, 이미지 2개 중 1개 Projector - Vivitek D855ST DMD Chip Board Replacement, Remove the housing: 2 단계, 이미지 2개 중 2개
    • Remove the following 8 screws securing the bottom housing.
    • Remove 3 screws securing the top housing.
  3. Projector - Vivitek D855ST DMD Chip Board Replacement, Remove the top housing: 3 단계, 이미지 2개 중 1개 Projector - Vivitek D855ST DMD Chip Board Replacement, Remove the top housing: 3 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry the top housing around the sides.
    • Slightly lift from the front and push it toward the rear of projector to free the mounting tabs.
  4. Projector - Vivitek D855ST DMD Chip Board Replacement, Remove top shield: 4 단계, 이미지 1개 중 1개
    • Remove the following 8 screws of various sizes on the top shield.
    • Remove the screw in red very last. It's tight and after removing the others, you can swivel the shield enough to loosen that screw without stripping it.
  5. Projector - Vivitek D855ST DMD Chip Board Replacement, Remove main board: 5 단계, 이미지 3개 중 1개 Projector - Vivitek D855ST DMD Chip Board Replacement, Remove main board: 5 단계, 이미지 3개 중 2개 Projector - Vivitek D855ST DMD Chip Board Replacement, Remove main board: 5 단계, 이미지 3개 중 3개
    • Remove one screw and the carefully disconnect 2 ribbon cables and 8 cable connectors from the main board.
    • Remove the 6 video cable standoffs from the rear of the projector. Needle-nose pliers will loosen them enough then a Torx-8 driver fits perfect to loosen them the rest of the way
    • Carefully push the rear of the video ports inward to push the board enough forward and lift up.
    • Lift up and disconnect the cable connector on the bottom of the board to the power supply.
  6. Projector - Vivitek D855ST DMD Chip Board Replacement, Remove power supply: 6 단계, 이미지 3개 중 1개 Projector - Vivitek D855ST DMD Chip Board Replacement, Remove power supply: 6 단계, 이미지 3개 중 2개 Projector - Vivitek D855ST DMD Chip Board Replacement, Remove power supply: 6 단계, 이미지 3개 중 3개
    • Remove 2 screws on the right and left sides toward the bottom securing the power supply to the chassis.
  7. Projector - Vivitek D855ST DMD Chip Board Replacement, Disconnect the power supply: 7 단계, 이미지 2개 중 1개 Projector - Vivitek D855ST DMD Chip Board Replacement, Disconnect the power supply: 7 단계, 이미지 2개 중 2개
    • Disconnect the cable connectors from the left and right sides under the power supply
  8. Projector - Vivitek D855ST DMD Chip Board Replacement, Remove the lens unit: 8 단계, 이미지 1개 중 1개
    • Remove the following 3 identical screws to remove the lens unit.
  9. Projector - Vivitek D855ST DMD Chip Board Replacement, Remove the heatsink: 9 단계, 이미지 3개 중 1개 Projector - Vivitek D855ST DMD Chip Board Replacement, Remove the heatsink: 9 단계, 이미지 3개 중 2개 Projector - Vivitek D855ST DMD Chip Board Replacement, Remove the heatsink: 9 단계, 이미지 3개 중 3개
    • Remove one screw and the tension bar holding the heatsink to the DMD Board
    • Pull back the shielding tape from the heatsink to the lens unit.
  10. Projector - Vivitek D855ST DMD Chip Board Replacement, Access to DMD board: 10 단계, 이미지 3개 중 1개 Projector - Vivitek D855ST DMD Chip Board Replacement, Access to DMD board: 10 단계, 이미지 3개 중 2개 Projector - Vivitek D855ST DMD Chip Board Replacement, Access to DMD board: 10 단계, 이미지 3개 중 3개
    • Remove 4 screws securing the DMD board to the lens unit
    • Pull it gently apart. It is held by thermal paste.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
dustind
회원 가입일: 04/26/11
211 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 16
전체 시간: 1,340
