주요 콘텐츠로 건너뛰기
ProntoTec Axius Battery Replacement
필요한 것
  1. ProntoTec Axius Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place the tablet face-up on a flat table
  2. ProntoTec Axius Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
  3. ProntoTec Axius Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
  4. ProntoTec Axius Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Using a spudger remove all the tapes that touches the battery.
    • Be careful not to cute any wires that are under the tapes
  5. ProntoTec Axius Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Using a soldering iron, heat up the contact point of the red wire from the battery and the motherboard.
    • When the solder begins to melt, use pliers to gently pull the wire from the motherboard
    • Don't leave the soldering iron too long on top of the wire so it doesn't melt any other component in the motherboard or surrounding the area.
  6. ProntoTec Axius Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Repeat Step 5 on the black wire connecting the battery to the motherboard as shown in the photo.
  7. ProntoTec Axius Battery Replacement: 7 단계, 이미지 2개 중 1개 ProntoTec Axius Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Using a spudger, gently pry the battery from the back of the screen to remove it from the device.
결론
작성자
4다른 기여자 명과 함께
Antonio Irons
회원 가입일: 10/20/16
441 평판
안내서 4개를 작성함
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G3
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 414
