주요 콘텐츠로 건너뛰기
Propane Grill Regulator & Hose Replacement
필요한 것
  1. Propane Grill Regulator & Hose Replacement, Battery, Regulator & Hose: 1 단계, 이미지 1/2 Propane Grill Regulator & Hose Replacement, Battery, Regulator & Hose: 1 단계, 이미지 2/2
    • Completely close the propane tank by turning the valve on the top clockwise. This prevents propane from leaking during the replacement.
    • Breathing in or swallowing propane can harm your health.
    • Turn the knob on the hose counter clockwise to disconnect it from the tank.
  2. Propane Grill Regulator & Hose Replacement: 2 단계, 이미지 1/2 Propane Grill Regulator & Hose Replacement: 2 단계, 이미지 2/2
    • Find the electric igniter on the grill and turn it counter clockwise to reveal one AA battery.
    • Replace the old battery with a new one.
  3. Propane Grill Regulator & Hose Replacement: 3 단계, 이미지 1/1
    • Locate the orifice that connects the base of the grill and the hose to one another.
    • An orifice is a valve commonly found on gas powered home products. This allows the gas to pass through from the source (i.e the propane tank) and burn properly.
    • Conncected to the orifice should be a nut. Use the crescent wrench to turn the nut counter clockwise and remove the hose from the base.
  4. Propane Grill Regulator & Hose Replacement: 4 단계, 이미지 1/2 Propane Grill Regulator & Hose Replacement: 4 단계, 이미지 2/2
    • Begin hand tightening the new hose to the nut that is connected to the orifice.
    • If you over tighten the bolt or do not hand tighten it first, you could cross thread the orifice and create more problems for the grill.
    • Once it has been adequately hand tightened use the crescent wrench to finish securing it to the orifice.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Evan Jureski
회원 가입일: 03/16/17
141 평판
안내서 1개 작성함
Missouri Western, Team S40-G12, Kunkel Spring 2017 Missouri Western, Team S40-G12, Kunkel Spring 2017 회원
MWSU-KUNKEL-S17S40G12
1 회원
안내서 2개 작성하였습니다
댓글 2개
I have a Napoleon travel series P285Q X. Do I need to purchase a control valve with a hose to convert from a 1 - 20 lb tank?
Rob Fillion - 답글
Question. Do I need to purchase a pressure valve and a hose to convert from a 1 lb to a 20 lb tank. The bbq is a Napoleon 285 pro series travel.
Rob Fillion - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 21
30일 전: 121
전체 시간: 6,430
