소개
When drones crash into obstacles or the ground, parts can be damaged. Debris (any foreign material) may become lodged in gears and cause them to break, or blunt force may damage them.
If your drone’s rotor assembly isn’t functioning properly because of damaged or dirty parts, then this guide is for you.
All four of the drone’s rotor assemblies are the same (minus the camber of the propellers, two of which are labeled A and the other two, B). This guide can be used to repair any of these by replacing their broken components.
필요한 것
댓글 한 개
I have a PROPEL GRAVITON drone and have not had it out in awhile. I got it out tonight and noticed a wire coming from the back of the camera, but I don't see where it is supposed to be attaches on the other end. None of the pics I see of this drone show this wire, though I wonder if it may be an antenna wire or something. Do you have any ideas?
