이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the 4mm screw that holds the propeller to the axle using a Phillips #00 screwdriver.
Remove the propeller by pulling it upwards away from the assembly.
Remove the three 6mm screws holding the propeller guard with a Phillips #00 screwdriver
Using your finger, gently push on the top of the propeller axle and remove out of the bottom of its housing.
Remove the wheel bearing from the axle using your fingers.
Remove the wheel bearing from the axle housing with a pair of tweezers.
Gently pry the top and bottom drone housing apart with a spudger to reveal the motor.
Replace the motor (if it is necessary).
댓글 한 개
I have a PROPEL GRAVITON drone and have not had it out in awhile. I got it out tonight and noticed a wire coming from the back of the camera, but I don't see where it is supposed to be attaches on the other end. None of the pics I see of this drone show this wire, though I wonder if it may be an antenna wire or something. Do you have any ideas?
