소개
Replacing the bottom propellor blades is the most common and easiest repair you will make on your helicopter. Propellors are often damaged when the helicopter crashes and replacing them is as easy as unscrewing them and screwing on new ones. Be sure to keep track of the tiny screws to avoid losing them.
필요한 것
Remove the two 5.0 mm Phillips #00 screws from the rotors.
The blades will fall off when the screws have been removed.
거의 끝나갑니다!
결론
