소개
You may need to replace your helicopter's drive gears if they become damaged or stripped. Replacing the gears will require you to completely disassemble your helicopter, so make sure to place small parts and screws in a safe place to avoid losing them.
필요한 것
Place the tweezers on the sides of the links and pull straight away from the top point of connection.
Remove the two 5.0 mm Phillips #00 screws from the rotors.
The blades will fall off when the screws have been removed.
다른 2명이 해당 안내서를 완성하였습니다.
