소개
This guide will help you to replace the joysticks in the remote controller for your Gyro-X. You may need to do this if you dropped the remote and broke or jammed the joysticks. The many screws holding the remote case together are set deep in the case, so you will need a long, narrow screw driver to remove them.
필요한 것
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
