소개
After rough flights the stabilizer beam may end up getting damaged. Without a working stabilizer beam, the gyro-copter will not fly as it should. The best way to fix this is by replacing the stabilizer beam completely.
필요한 것
Place the tweezers on the sides of the links and pull straight away from the top point of connection.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
