소개
In this guide you will learn how to remove and replace the top two propellor blades of the Gyro-X. This is a common procedure, because crashing your Gyro-X will often result in propellor damage. To remove the propellors you will only need to remove 4 small screws. Be careful not to lose these after removal.
필요한 것
Place the tweezers on the sides of the links and pull straight away from the top point of connection.
다른 한 분이 해당 안내서를 완성하였습니다.
