주요 콘텐츠로 건너뛰기
Propel Star Wars T-65 X-Wing Drone Remote Control Battery Replacement
  1. Propel Star Wars T-65 X-Wing Drone Remote Control Battery Replacement, Remote Control Battery: 1 단계, 이미지 1/1
    • On the right side of the controller, slide the small screw driver out.
  2. Propel Star Wars T-65 X-Wing Drone Remote Control Battery Replacement: 2 단계, 이미지 1/1
    • Flip the controller over, so the black panels are facing up.
  3. Propel Star Wars T-65 X-Wing Drone Remote Control Battery Replacement: 3 단계, 이미지 1/2 Propel Star Wars T-65 X-Wing Drone Remote Control Battery Replacement: 3 단계, 이미지 2/2
    • Unscrew the small screw on the left bottom side. The screw should be on the plastic piece that has an upwards facing arrow.
    • Repeat for the screw on the bottom right hand side.
  4. Propel Star Wars T-65 X-Wing Drone Remote Control Battery Replacement: 4 단계, 이미지 1/1
    • Pull the plastic piece off to reveal the compartment where the batteries go.
  5. Propel Star Wars T-65 X-Wing Drone Remote Control Battery Replacement: 5 단계, 이미지 1/1
    • Remove the old batteries.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Miranda Brinkley
회원 가입일: 10/22/18
512 평판
안내서 3개 작성하였습니다
UC Davis, Team S11-G5, Lore Fall 2018 UC Davis, Team S11-G5, Lore Fall 2018 회원
UCD-LORE-F18S11G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 21
전체 시간: 2,314
